Shows error code 117-313 and 116-324
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
SOURCE: error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
SOURCE: Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
voltage sag that causes the PEST test to fail.
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error. Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Check for obstructions in the Wiper Assembly path.
Is the Wiper Assembly obstructed by the Printhead or wiring?
