Hello, First off check your anti freeze make sure it is filled that gives off a code in Dodge Calibers, also if you have the code numbers do an search online it will tell you what it is you need to change or service.
Take it to autozone or checker auto, orielly, precision etc. They can scan it for error codes for free. Then you can get a better idea of what is wrong.
the best thing to do is to take it to auto-zone or advanced auto parts, and they will scan it for free. as long as the check engine light is on. to find the problem code. to tell what the problem is or where the problem starts. repost if need be. after codes are read. good-day !
These code readers are 100% reliable. If you feel it is not getting enough fuel it means there is problem with the ignition. But the actual technical reason is that the timing controls the ignition of the car. If the timing is wrong the problem you are facing can surely happen.
Take it to Advance Auto Parts, or Auto Zone, they will scan your computer for free to get the code and tell you what it means. May just be a sensor, or the gas cap isn't tight (emissions) may or may not be serious. Thanks.
first you should take the truck to auto zone or advance auto, oreilly's and have the code read. its free and it will tell you what the problem is. just tell them the check engine light is ON
you need to check the grounds if they shorted the sytem they may have damaged the grounds one bad connection can cause lots of problems if it will drive you could take to auto zone an they will run codes an tell you whats wrong if you can not drive it google your van an ask how to read codes it will tell you how to jump the connector an read codes from the check engine light
