ATTACHMENT FITS ON TO HOSE AND SPINS TO GRAB PET HAIR OF FURNITURE.
SOURCE: shampoo furniture
I have had a Kirby for over 20 years and yes you can shampoo your furniture. You do it just as you would your stairs or as if you were spot cleaning. There is really nothing to it.
SOURCE: kirby paint sprayer attachment
HERE is the manual, just instead of shampoo use water-based paint and do nut put that nozzle on the sprayer. WASH IT WELL after you use it. Honestly - you better off buying a spray can. Painting with Kirby - MESSY. May sound strange from someone who makes living selling Kirby stuff but I just hate salespeople making it sound as if Kirby vacuum is ONLY appliance that you ever need to buy...
Rocky
SOURCE: I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
SOURCE: My Kirby Ultimate G does not have enough suction
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
SOURCE: Green light no on
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
