Question about HP cp1700 Color Inkjet Printer
Expired HP printer cartridges
I have been given an HP CP1700 printer. I get a message that the black cartridge has expired. I do not know if the printer works so am reluctant to spend money on cartridges only to find that something else is wrong. The system indicates taht the cartridge is over 90% full anyway. Is there any way of fooling the printer into accepting an old cartridge - even on a temporary basis so I can check if anything else is wrong?
  • 1 more comment
  • Anonymous Jul 29, 2008
    Same problem. I don't have the same registry string in the post that walks you through modifying it.
    Where is the battery located please?
  • Gerald Walker Nov 21, 2008
    Thanks fellas. Removing the battery and replacing it did the trick. Will bear other comments in mind if the problem arises again.
  • Anonymous Mar 16, 2009
    Message states cyan ink cartridge expired but I replace the cartridge and it still will not recognize that its 100 percent full.
I have the identical problem with an HP Business Inkjet 1100.
Once cartridges were past date, the printer would no longer print from Windows XP. It would however work perfectly from Linux.
I did not find an ini file as mentioned in other posts, and I really did not want to open the printer as it worked fine in Linux.
The following fixed the problem:
1) Click on Start button, run
2) Type in regedit, enter
3) Navigate to HKLM/software/Hewlett-Packard/HP Printers/HPWH Toolbox/Common
4) In the right panel, right click on Ink, pick modify
5) Change 0100 to 0000
6) Save and reboot
Posted on Apr 04, 2008
    New Friend:
On the CP1700 I was able, through other forums, to locate the battery causing me no to be able to use perfectly fine but recently expired ink. It took me a while to locate it and some nimble fingers to fix it but it has saved me a ton of money.
1. unplug 2.locate the battery 3.slide a piece of clear plastic (from retail packaging) between the contact and battery 4. wait an hour 5. plug back in and voila!
Posted on Jun 07, 2011
Hi everyone HP Cartridge expiration problem solved
Model : HP Business Inkjet 1000 series
Problem : Cartridge Expired
Solution : Normally you can't override cartridge expiration date problem but you can hack and overcome from the problem. As per the documents from the web saying this model can remember up to 3 cartridge of one particular colour. Normally each cartridge will expired within 2 1/2 years.
Mine also expired. To disable the link level feedback to system you have to unplug some cables inside of the printer. So you have to search web for that. I was also refilled the cartridge and reuse it upto 2 1/2 years. After that my 4 ink cartridges were expired and refuse to print even the ink levels were good.
How to overcome this problem. HP the International company's cartridge protection technology having some loop hole in their protection. They want more business than what they are selling. They don't like people refill and use their cartridge. They want to force the user to buy new cartridge get more profit.
Normally the each cartridges portion in the printer recognize and memorize the chip bottom of the each cartridge. For example the black cartridge part the printer recognize the chip fixed bottom inside the black cartridge. It won't check or memorize the other color cartridge chips.
I just removed the chip of the black using a nice blade and swap the chip of the pink (double side glue is used to paste the cartridge chip. You have to very carefully do this. Otherwise chip will damage). Do the same trick to other two cartridge. After you swap note down which cartridges you swaped and keep it in safe place. Later it is useful to swap it again. Better swap (1 and 2) (3 and 4). At least you can swap and use the cartridge for 10 years.
Other model of Business inkjet you have to try it yourself. It may work. Best of luck.
Posted on Aug 24, 2008
    New Friend:
On the HP Color Inkjet CP 1160 Printer Just remove the battery
and throw it away. Cause once you remove it, it is almost impossible
to replace it back into the printer. Its located on the lower left side
of the printer on an upside down circuit board.
Posted on Jan 12, 2013
HP business inkjet 1200 solution for expired cartridges. There is a 9 pin connector located under the ink cartridges. The cover can be removed by prying it off. It is held in by 4 fingers the lock it in place. Under the cover there is a plactic barrier that I cut the middle section out to get access to the connector. I unplugged the connector and removed the white wire and plugged the connector back in and my expired cartridges work just fine.
Posted on Sep 29, 2009
If you have a problume with No. 10 Cartridge; You only replace their bottom cover with same cartridge( that have a longer expiry time but empty).
Posted on Feb 17, 2010
    New Friend:
OK everybody, The simple way to fix this problem is to reset the printer. All of the newer printers have a battery inside. I just slipped a piece of plastic between the battery and the clip and left it there for about five minutes. Removed the plastic and presto. The internal record keeping info is reset and I am printing again. I did this on two HP CP1700's and it worked fine
Posted on Jan 29, 2010
  • kimberly Jul 23, 2013
    where is the battery located
A new yellow cartige was inputed but the printer states that is missing.
  • 59 Answers
Honestly, the only easy way is to get new ink cartridges. However, most HP's have a battery in them. Taking out the battery and leaving it sit for a while and taping the end of the battery will reset the dates in your printer. But those take HP 10's & 11's. Chances are if has sat, your printheads are bad as well. So the true question is do you want to spend 34$ a whack for each print head, and then for the ink? If you replace each head and say get the large black, you're spending nearly $200. I'd say if you're not sure, get the ink refilled at your local cartridge world, and try it then. They re chip the 10, so it won't read expired. If it tries to print, then focus on the printheads
Posted on Jun 13, 2007
Limpia los cabezales
Posted on Nov 21, 2008
6ya staff
SOURCE:
I bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
I get the message that the yellow ink cartridge on my HP business inkjet 1000 has expired. I installed a new one and it still is locked up.
Unplug the printer and then plug it back in, did you take off the plastic on the new printer cartridge before you installed it.?
May 25, 2010 | HP cp1700 Color Inkjet Printer
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
Oct 24, 2008 | HP cp1700 Color Inkjet Printer
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Apr 07, 2008 | HP OfficeJet d145 InkJet Printer
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP cp1700 Color Inkjet Printer Logo
7,796 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
