Prince Fusion Table Tennis Table Logo
Posted on Dec 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do we close 1 1/4" gap between two sides of table
The sides are attached to two stationary legs. The manual was incomplete and I don't know where to get them on the Internet.
Anonymous
Level 2:
Champion:
New Friend:
  • Expert 217 Answers
  • Posted on Dec 18, 2012
Anonymous
Expert
Level 2:
Champion:
New Friend:
Answers
217
Questions
15
Helped
108166
Points
371
You probably have either (a) not properly extended the legs all the way, or (b) have attached some of the cross beams on the wrong side.
http://www.sears.com/prince-fusion-table-tennis-table/p-00601215000P
click on this link and you can move the magnifying glass over different parts of the picture to see up close what the table should look like in the correct and finished position.
What is a walk-in picnic table?
A walk-inpicnic table has benches attached all around but there are gaps in the benchesto allow people to get in and out easily without having to climb over. Here isa link to one although there are cheaper ones available if you don't want toget it in wood. http://www.amazon.com/Cedar-Octagon-Walk-In-Picnic-Table/dp/B001PKZF2C
Jul 25, 2012 • Furniture
1helpful
How can I make a really cheap sofa table?
Cut ListCut List: A) 4 - 1x3 @ 29 1/4" (Fronts and Backs of the Legs) B) 4 - 1x2 @ 29 1/4" (Sides of the Legs) C) 2 - 1x3 @ 10" (Side Support) D) 1 - 1x2 @ 37" (Stretcher) E) 2 - 1x3 @ 37" (Side Trim for the stretcher) F) 2 - 1x4 @ 10" (Side Apron) G) 2 - 1x4 @ 37" (Front and Back Apron) H) 1 - 1x12 @ 48" (Base for the top) I) 2 - 1x4 @ 11 1/2" J) 1 - 1x12 @ 41"
Step 1
Download Original]'>untitled-3%20(15).jpgConstruct your legs by nailing through the 1x3 legs into the edge of the 1x2 legs with 2" nails and glue. The legs will be positioned with the 1x3s to the front, 1x2s to the side, as shown in the diagram.
Step 2
Download Original]'>untitled-4%20(14).jpgStart by marking each of the legs 5" from the bottom of the board. This will be the bottom of the side support, C. Nail C to the legs, using 1 1/4" nails and glue, from the inside.
Step 3
Download Original]'>untitled-5%20(13).jpgNow add the stretcher, D, centering D on the support, C, but keeping the top edges flush. D will lay flat, with the wide side up. This is demonstrated above. Use glue and 2" nails, nailing through the support, C, into the end of D.
Step 4
Download Original]'>untitled-6%20(9).jpgAdd the side trim pieces, E. First, nail through the supports C into E, using 2" nails. Then nail down the length of the stretcher, taking care to keep the top edge of the stretcher (D) perfectly flush with the top edge of the stretcher support (E). Use glue and 2" nails.
Step 5
Download Original]'>untitled-7%20(8).jpgNow use the 1 1/4" nails to nail through the back of the side apron pieces, F, into the legs. Use glue. Keep top edges perfectly flush.
Step 6
Download Original]'>untitled-8%20(7).jpgDo the same for the front and back apron pieces, G, as shown above. Nail through G into the legs using 1 1/4" nails and glue. Keep top edges flush. Take a minute to check for square
Step 7
Download Original]'>untitled-9%20(7).jpgNow add the base top, piece H. Keep the front and back edges flush with the legs, but let the sides overhang 4" on either side. Nail into the legs and the apron using 2" nails and glue.
Step 8
Download Original]'>untitled-10%20(6).jpgUse glue and 1 1/4" nails to attach the breadboard ends to the base top. Keep all outside edges flush.
Step 9
Download Original]'>untitled-11%20(5).jpg I recommend not cutting the final piece, J, unitl you have taken an exact measurement. Add the final piece, using glue and 1 1/4" nails.
Finishing Instructions
May 29, 2012 • Furniture
Installing dishwasher --- what is a Cabinet Seal Kit - that is mentioned in the instructions? We have a big gap between the brackets that attach to the countertop and the dishwasher itself that cannot be...
no,,the seal that fits on the top snaps on from the front and you have to lift top mounting brackets up than kind of work the two brackets back down,,or you can just unclip the mounting bracket .snap top seal than than put brackets back,,clip hold the seal down some,,,those side and top seal are mostly to stop a person from cutting ther hand if unit is pertruding a little...now to make dishwasher reach the counter when legs are down all the way..get to peices of wood the lenght of unit front to back just short of front toe panel..i cant help with thickness because you have to measure the gap from counter,,some times i find that the wooden slats that came with the dishwasher works great...good luck..anymore ideas needed just repost
3answers
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 • Garden
I need instructions for the genki house baby carrier and for the bubba moe baby sling
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
  1. Hold your baby close to your chest
  2. Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
  3. Still holding baby close to you, place sling straps over your shoulders.
  4. Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
  5. Thread the strap through D ring with one hand whilst your other hand still holds the baby.
  6. Simply 'hook' the strap through the D ring with your index finger.
  7. Do not change hands at this stage.
  8. Tension strap backwards - away from your back and don't let go.
  9. Feel the baby's weight now firmly supported by the sling at your waistline.
  10. As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
  11. Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
  12. Check the position of the baby - you should be able to kiss his/her head.
  13. Baby can also face outwards when he/she gets older.
Jun 15, 2011 • Baby Gear
1helpful
2answers
I have a LG LD 2140WH diswasher, it only works for 2 min then give a OE error code. what can be wrong
The possible reasons could be
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
104helpful
11answers
How do I remove the legs from Leapfrog Musical Table
Turn the table on its side. On the top of the outside of the legs are two slits, where they connect to the table. Slip a butter knife in the area between the slits, and press in (not up or down) hard! The legs will pop off in a few tries if you do it hard enough :o)
Jan 15, 2009 • Toys
Top Prince Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Prince Sport and Outdoor - Other Expert? Answer questions, earn points and help others
