Kyocera FS-3900DN Laser Printer Logo
Posted on Jan 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kyocera Ecosys FS-3900DN in HP emulation mode
How do I set a
The Printer is a:
Make: Kyocera Mita
Model:Kyocera Ecosys FS-3900DN
Driver: Kyocera Mita FS-3800
to run in HP emulation mode ?
  • Anonymous Mar 23, 2014
    problem kyocera fs 1030 mfp ereur cf000
Anonymous
Level 3:
Genius:
  • Master 2,120 Answers
  • Posted on Jan 23, 2009
Anonymous
Master
Level 3:
Genius:
Answers
2120
Questions
0
Helped
670100
Points
5011
Right click on the printer icon and choose properties. Your emulations are listed there.
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
1helpful
Hi, I have a problem with my Kyocera FS-3900DN. The display shows the fault 7410:0043899. How can I fix it? Thanks
Will just reflashing the firmware fix this?
I have replaced the EEPROM (as per my post near the top) on a few of these, so that the printer will come to ready and then flashed the EEPROM via parallel port with upto firmware.
skyp techbelkin
2helpful
2answers
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
1helpful
2answers
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
Installing a kyocera fs 3830n printer on applemac
See if this is set to pcl6, make take care of it.
(from manual)
Changing the Emulation
To change the emulation mode, proceed as follows:
1 Press the MENU key.
2 Press the or key repeatedly until Emulation appears. One of
the emulation modes shown below appears, indicating the current
emulation.
PCL 6 (default)
KPDL
KPDL (AUTO)
Line Printer
IBM Proprinter
DIABLO 630
EPSON LQ-850
KPDL is the Kyocera’s implementation of the PostScript page
description language.
3 Press the ENTER key. A blinking question mark (?) appears.
4 Press the or key repeatedly until the desired emulation mode
appears.
5 Press the ENTER key.
6 Press the MENU key. The message display returns to Ready.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
