Are tabs up or down for on setting
1) Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
2) Use link above to Experiment with features
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I bought brinks ez dial
Smart thinking using wall timer instead of buying new coffee pot.
I'll remember that tip.
I test timers.
A lot of timers arrive defective, and other stop working short while later.
Some last for many years.
On your timer, make sure slide switch is pushed all the way over to TIMER or TIMER ON.
Plug regular lamp into timer, turn lamp ON, and manually rotate timer dial clockwise to see if timer trippers will turn lamp ON-and-OFF.
If timer functions with manual rotation, then see if dial rotates on it's own.
The dial should rotate, or else timer is defective.
If dial rotates, and timer works for lamp, then double check that your coffee pot is ON at all times.
The timer just opens the circuit to coffee pot, but coffee pot has to be ON.
Also take advantage of fixya phone support for any type of problem.
For a price, fixya expert talks to you over phone to resolve repair issues.
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
