Oven works every now & then and flashes a code ,EEEE or something like that.
SOURCE: Whirlpool oven
if you get down to the control panel first try plug and unplugging all the connectors as resistance can cause this in the connectors next take the Mylar ribbon off the control and clean it softly with a pencil eraser as the touch pad malfunction can cause now if you have an ohm meter you can ohm the oven probe it should be 1200 ohms at 70 degrees room tempture if all this fails to fix it then replace the controls bd ive seen too many techs too quick to replace a 200.00 control board just because the eoc spouts out an error code
SOURCE: Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
SOURCE: WHIRLPOOL RF385PXG
If a new temp sensor doesn't fix an F3, you have a loose connection, or the electronic control is bad.
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
