The TV is working just fine how can I get the picture to fill the screen?
SOURCE: HD broadcast picture is not full screen. How do I
go into your customers setting and change you aspect setting to either full or auto
SOURCE: Insignia flat panel tv
I don't exactly know your model. I can give you a generic type answer.
I can tell you that when you select to have the full screen, it may not work in the mode for the tuner. The reason is that the programs coming in from your tuner are actualy 4:3. When asking for a full screen you are asking for a 16:9 type format. This would stretch a 4:3 picture.
Have you tried contacting the manufacture, or if you know their local factory support place for your area?
Jerry G.
SOURCE: how to make a flt screen in to full screen picture
On your remote there should be a ZOOM button that will strech the screen to full screen it may not be a desirable look but most formats today for HD tv is widescreen format also in your menu system you can change this as well. thanks for using fixya please click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: My HP PL4260N doesn't show
surely there is problems with the lcd controller... you need a qualified technician to check the power consistency in your lcd controller.
SOURCE: A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
