I don't know if you'll find a free one, but here are some links to try for ones for sale
Instruction Manual Simplicity SL200
Simplicity Serger Sl200 Manual downloadfreefileshere com
http://www.mastersewusa.com/info_simplicity_200.html
Simplicity SL200 Instruciton Manual
SOURCE: my simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
SOURCE: I need a manual for Simplicity Pro Serger SW432
I went to Simplicity's website and downloaded the manual for free. Hope this helps.
SOURCE: Need manual for Easy Lock 804 serger
Mine was destroyed in the floods a few weeks ago and I found a download and printable one at simplicityhomecare.com click on the download tab and select manuals and then under sergers chose your model. Good luck with your project.
SOURCE: just got a used simplicity serger how to use and
Sergers are used to finish raw edges.
Not the best choice for quilting and purse making.
