I will take pictures and they are fine, and then the next shot will have pink on the screen and wavy lines. When you download and go to print they come out pink, the rest of the picture will be fine. I figure it has to be an error on my side, but I don't know what I'm doing wrong. When the screen goes pink and you press the shutter down to fix your view the letters AF come up on the screen in brown. Any thoughts?
SOURCE: Kodak EasyShare P850 - Black screen
I have fixed several Kodak models including this one with exactly the same problem. Sometimes tapping on the side will fix it temporally. The fix is to open the back of the camera and snap the connector from the lens. If the camer is dropped the connector can come unsnapped. You should only attempt this if you have had some experence working on electronics. Be careful inside the camera especially in the upper right corner which is where the high voltage is for the flash. You can get a large shock from this camera if your not careful.
SOURCE: black screen all the time
i want to install the device to get pitchers in my computer sice i lost installation cd
SOURCE: pictures are pink with lines
The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
SOURCE: my kodak easyshare M753 has pink tint and lines
its obvious a malfunction that didn't occur by bad handling ..and if the device it is still in the warranty period , my advice is to go for it if you never open it or other things that you wouldn't suppose to do
SOURCE: pictures turn out pink & with lines in it.It
Try to reformat your internal memory, and then turn On the camera and use the auto mode or smart scene mode. Take a two pictures on a same subject then review the pictures after, now if the two pictures has lines on it and it has a pink in colors it means that the lens of the camera is defective that`s why it will not take a good picture. Please call kodak 1 800 235 6325 so you can request for repair
