Connected to WiFi but is slow to connect with poor signal
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep
the router and your connecting device away from other electronics. You
should especially keep away from phones, fax machines and microwaves.
etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following
these steps would give you stable internet connection and also
increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
SOURCE: My wifi has signal and
try using other browser i.e. mozilla firefox or google chrome. have you check the browser settings of your internet explorer
Possibly a router issue. It shows the connection but it must be completed through the manufacture website.
