Rangemaster 110 (Gas) Kitchen Range Logo
Posted on Feb 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a rangemaster 110 and one of the rings is playing up. It lights and then after a few seconds pops and blows itself out. Even when it is lit and running, after 10 secs or so it does it again. I have tried cleaning all parts including the jet. It is running on propane. Any ideas please??
dik stukkien
Level 2:
Scholar:
New Friend:
  • Expert 69 Answers
  • Posted on Feb 07, 2018
dik stukkien
Expert
Level 2:
Scholar:
New Friend:
Answers
69
Questions
0
Helped
22283
Points
294
it is always terrible when items does not work as it should.
I expect that this cooker has flame safety.
The first thing I suspect, is your FFD (=flam failure device). Besides the burner are 2 points, one is for the spark, the other is the sensor for the safety device. On that point is connected a thin copper "wire" that goes to the tap. There it is screwed in.
The test is, stays the burner on when you keep the button pressed in. If that is the case, and the burner goes out after letting go the button, then I am sure it is the FFD.
I hope this helps, Kin regards, Dik
5 Related Answers
Anonymous
  • Posted on Feb 10, 2008
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
Anonymous
  • Posted on Jan 27, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
jeremyovitt
  • 12 Answers
  • Posted on Feb 20, 2009
SOURCE: Rangemaster 110 gas grill flame
your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
If you need further help, reach me via phone at https://www.6ya.com/expert/jeremy_075aa344198c3329
Anonymous
  • 188 Answers
  • Posted on Mar 26, 2009
SOURCE: Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Anonymous
  • Posted on May 19, 2009
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Rangemaster 110 Ovens spark but won't light
Its the spark box repeating check the elcrtode is not damaged /cracked . if not it sound slike a faulty box
1helpful
The Wok burner gas flow is really low and grill won't stay on
Bolcked injectors and blocked burner jets . I would also check and see if you have a valve on the that might be not be fully on . All points to lack of gas pressure I would also check the reg on your tank or bottle .
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
How to fix problems with hob not staying alight on rangemaster lpg
If you are holding the knob in for a good few seconds and finding that it still goes out, the thermocouple has failed on that hob. The thermocouple is the metal spike sticking up when you take the ceramic plate and carrier off each ring. First check that the ring pieces are correctly sitting on the cooker, but if they are you will need that thermocouple replacing.
1helpful
Rangemaster 110 oven heats by itself
That happens either because the timer control is faulty, or because there is a contact on the element wires or connectors, and the element is grounded.
Control board and wiring harness are tested using a multimeter.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
6helpful
3answers
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
4helpful
Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
1helpful
Gas oven operation
spark should stop when burner is lit.clean the probe with a light sandpaper and see if this corrects it.
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
