SOURCE: my m.p.3 phillips gogear vibe
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair:
Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
Hope this works.
SOURCE: When i turn on the
You can repair your device via this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=FLASH_AUDIO_PLAYER_SU&cat=MP3_MEDIA_PLAYERS_CA&grp=SOUND_AND_VISION_GR&session=20110215050442_93.189.114.198&ctn=SA1VBE04K/17&mid=Link_DiagnosticInformationTool&hlt=Link_DiagnosticInformationTool
At
first click on "Repair/Update" and "how do I repair.." and go on step
by step. Finally you should get to "connect device in repair mode" and
do all described there and I hope your device will come back to work
again correctly.
Thanks. Good luck!
gylacz
SOURCE: nee a manual for philips
There are several different submodels of the SA2RGA. You'll find the manuals for them at the following sites:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04R/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04S/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA08K/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04KS/37
SOURCE: my philips gogear mp3 vibe sends the message "must
First of all have you loaded the gogear from the philips media converter and is the whole space filled up. In some cases there must be a space on the memory as the system may work very slow if the memory is full. Try and delete some files in this case. Also load only safe files that are scanned and has no malwares.
Hope you try this out.
