Possible that there is a short within the power supply, the motor or the capacitor. You will need to check by disconnection of the circuits in isolating till trip over stops. Also if this is a ELCB then there can be leak in the circuit that trips due to the ground leak.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
