SOURCE: hp pavillion dv2214tu driver details
i hav HP Pavilion dv2000 (dv2214tu) its vista enble i want to put xp so my question is can i put xp on it
SOURCE: I installed Windows 7 and I cant find a driver for
When there is not a Vista version of the driver, then try installing the Vista version, it may work but may not have all the functions that it had under Vista.
SOURCE: my hp pavillion dv6000 video card nvidia geforce
~To download the manufacturers and
therefore correct drivers
or specific software; Always get your drivers
from the manufacturer of your Laptop, Notebook or Desktop. If you were to log on to the hp.com
web site, usually one is able to download if
available, by model number,
All available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing. This is the best way of ensuring up to
date drivers for your system and they are free of charge! There
are no XP drivers to be found with Microsoft as XP is no longer
supported. Some
manufacturers may have a limited number of Drivers still listed. I hope this helps.
SOURCE: hp pavillion converted into windows
Try 'roll back driver', follow these steps;
- Open Device Manger from the Windows 7 Control Panel.
- In Device Manager, locate the device that you want to roll back the driver for (her its sound driver).
(Navigate through the hardware categories by clicking the > icon. You can find specific devices
under these major hardware categories.)
- After finding the hardware you're rolling back the driver for, right click on the device's name or icon and click on Properties.
- In the Properties window for the device, click the Driver tab.
- On the Driver tab, click the Roll Back Driver button.
(If the Roll Back Driver button is disabled, Windows 7 does not have a previous driver to roll back to so you won't be able to complete this process.)
- Click the Yes button to the "Are you sure you would like to roll back to the previously installed
driver software?" question.
The previously installed driver will now be restored. You should see the Roll Back Driver button as disabled after the roll back is complete.
- Click the Close button at the bottom of the device properties screen.
- Click Yes on the System Settings Change dialog box that says "Your hardware settings have
changed. You must restart your computer for these changes to take effect. Do you want to restart your computer now?"
DONE, Hope this helps,
Please rate if this solution was helpful, thanks!
