When I put the batteries in the camera the batteries died too quick.
SOURCE: New Rechargable Batteries Die after A Couple of Pictures
This model is renowned for poor battery life. Some people say using the CRV3 battery lasts a lot longer but my advice is to buy NimH batteries with at least 2600mah. Some Nimh are only 700mah and obviously will last less than a third the time of a 2600. Keeping the use of the LCD to a minimum will increase battery life and using the flash puts a tremendous drain on the batteries so if you can do without the flash switch it off. Combine these tips with a set of 2600mah batteries and I'll guarantee you'll be pleasantly surprised. As a sideline I always have a good laugh when I see an Olympics opening at night or a firework display and all you can see is thousands of flashes going off which the majority only reach about 12 feet maximum and the parade being shot is some 300 feet away. BMW
SOURCE: Camera CX7430 battery problems
The company suggests lithium batteries. That has not helped! We are sending the camera to Kodak.
SOURCE: I have Kodak Easy Share CX7430. I have put in new
Enilra, sounds to me like you might have the button that takes the photo stuck in the down position. Without turning on the power, put you finger on the button and press down on it while you move wiggle your finger around. Get a good look at the button and see if You Can See If The Button is returning to the UP Position. Withour seeing your camera in person this would be my guess.
SOURCE: put brand new batteries in camera took three pic then they die
Hi, you will only solve this by buying the official KODAK battery (KLIC-8000) - NZD52.00 retail here in New Zealand. Even the generic CR3V rechargeable batteries dont work, so dont waste your $$ on them.
Even now, with the 'official' battery, when taking flash photos or zooming a lot, I find that it is only taking around 150 - 200 shots, when Kodak boast over 400.
But I must say the capabilities of the camera (esp the quality video) outstrip any annoyance battery wise.
Hope this helps, regards Wayne
SOURCE: batteries in my kodak easyshare camera don't last
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
