Unit was getting hard to start so did compression test(100lbs), inspected and cleaned carb, inspected fuel lines(no holes), replaced fuel filter and primer bubble, and cleaned spark plug, check gas tank vent and it is ok. unit will fire up and run for about 20-30 seconds and dies. i figured it has an air leak but can't find it.
Re: husqvarna k760 will not prime and/or run properly
It runs off the fuel from the priming cycle, so no fuel from impulse air/diaphram. Check impulse air line is properly connected, not cracked (leakin), else diaphram may need replaced (carb rebuild kit).
I think your on the right track Blowing compressed air through your tank vent is great but it is way more air than the natural asperation that the saw pulls on it own I would replace the vent cap and also look for a pinched fuel line between the fuel tank and the carb
Pull off the exhaust, does the piston look ok?
If scored thats not good.
If ok check fuel filter , pressure test lines or remove and check for cracks. Just a start but check easy stuff 1st or get back to me with more info, cheers
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
check for a spark first if you have then squirt some starting fliud in carb if it starts its ether it needs a valve job do compression test 100lbs or carb needs to be rebuilt
Are you referring to the fuel lines and if so did you get them mixed up and hooked on the wrong carb inlet? If so try reversing them and see if it starts.
You have confirmed that you have good spark. what you have left is to check for compression and fuel. Compression is needed for two reasons. The piston creates a vacuum that draws the air and fuel into the cylinder. The piston also compresses the mixture to get it ready for combustion. The only safe way to perform this test is with a compression tester. I have used my finger to run a quick test. To see if there is any compression but I can't safely describe how to do it that way. If you already know what i', talking about then it doesn't matter. After compression is tested and confirmed then you will more to the fuel system. You will need to start at the fuel supply line and determine that fuel is easily flowing to the carb. Then the carb will need to come of for a proper cleaning and inspection. These new carburetors don't last for ever. they are made of plastic and are not as strong as older metal versions. You CAN NOT use carb cleaner on these units. It will instantly destroy the jets. There is only one product that I use and recommend. Its called "Deep Creep" from Seafoam. it is a good product and it won't even melt Styrofoam. Take pictures during disasembly. There are small springs and rods that have to go back exactly where you found them. I hope this information helps. Please let me know how your repair is going and if you have any other questions, good luck,
hi
Install a new stock spark plug. Clean the air filter then remove and clean the carb. Drain the gas tank, clean out rust and any trash, and remove the fuel valve to clean the internal tank filters. Now install an in-line fuel filter in addition to the tank filter. What follows is just in case it will help out.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
There
is a proper way to start the engine. Four controls are on your bike to assist
in starting. Below are generic instructions.
The choke, used
when the engine is cold. Pull the red knob for choke.
The " Hot
Start " Lever, used when the engine is hot. Pull the lever to lean
the fuel mix when the engine has been running.
The de-compression
lever, always used.
The throttle, used
to prime the cylinder, (power valve).
Don't
kick, instead, push
the kick lever downward. You will feel the back pressure as the piston is going
upward on the compression stroke to the point the pressure is great enough that
the kick lever "locks up". You are very close to TDC. NOW, pull in
the de-compression lever. Push the kick lever a little bit more to get the
piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm,
(Power valve), in the carb gives a shot of gas when this is done. DO NOT
do this multiple times because you will flood the engine. Leave the
throttle closed when kicking. A flooded engine will often
backfire. Now give a strong kick through the full sweep of the kick start
lever. Quickly get your foot off the kick lever at the end of the kick to avoid
any chance of "kickback" from the kick lever. This happens in the
case of a misfire, aka > backfire. It can be very painful, and can even
break a leg. I am serious about that. Repeat the process (but without the
throttle priming), for six kicks. After six kicks go ahead and twist the
throttle again for a second priming. A good battery, a clean spark plug, a
clean carb and clean air filter will also aid in starting. Note that not
all carbs have a power valve. When a power valve is not present you should crack
the throttle open only 1/8 inch from closed on each kick.
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Hi If you have good compression and spark at the spark plug try priming the engine(put some fuel mixture in the spark plug hole),set the carb adjustment(highh speed H=3/4 turn and lowspeed L=1 1/4 turn,turn the scews clockwise until the end and then set them.Try to start the engine.If it runs only the gas you puted inside the cilinder and then stops you have a fuel delivery problem to find and fix.First disassembly ,check and clean the carb.Then the fuel filter and the hoses.Let me know. best regards savumihai71
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
