I am using the 8125 cingular phone and could not get to my "contacts". I am able to see my contacts listed but when I scrolled up and down to view my contacts, it has a beeping sound. I also tried pressing the "menu" and "new" buttons on the bottom and it too has a beeping sound as though the phone is locked. Please help. sharene
you need to solder it back into place ot instal a new one if yours is damaged. Please contact me if you are interested to send it in for this repair. cellularcpr@aol
If you have the right tools and are used to repairing small components it should be doable. there is a fragile flex cable that has to be navigated around thoough. if you not comfortable with that you can contact www.fixphonenow.com , the charge for that repair is $75 and turnaround time is about 1 day.
you have to contact T-mobile technical support and have them guide you through programming their internet settings on the phone. although the phone is unlocked the internet settings currently on the phone is for cingular. have them program the same settings as the t-mobile MDA phone (same phone as 8125, shipped for t-mobile)
You may need to upgrade the htc wizard to use 102.11g networks.
You can do this yourself if you follow these steps.
Google a program called total commander. download and install it on your phone.
Now open total commander. Listed on the very top of the folders list will be \\
-Click on \\
-then click registry (you are now in the devices registry, be careful not to change other things)
- select hklm (this stands for Hkey local machine)
you need to go to this location
HKEY_LOCAL_MACHINE\COMM\TNETWLN1\PARMS
(so you would choose comm, then scroll down to tnetwln1, then select that and scroll down to parms and select parms)
then assign the follow changes to the keys listed in PARMS...
Assign a value of 1 to dot11SupportedRateMask
Assign a value of 8 to dot11SupportedRateMaskG
Perform a soft reset (do this by holding the power button for roughly 6 seconds, until a box comes up asking you if you want to shut off the device. Turn it off, then turn it back on and the changes will go into effect)
Then simply try to log on your router
Peter
