I plugged in my sansa into my friends computer with Rhapsody, so it automatically "upgraded". I only thought the upgrade would help my mp3 player so I let it load. Ever since I unplugged it, it takes a couple more seconds to pick and play a song and it's just a lot slower to do things. I just recently charged my mp3 player, and when I listened to it, about a hundred of my songs were deleted. I noticed that most of the deleted songs were the ones I had been listening to a lot recently. Did the Rhapsody upgrade mess up my sansa?
Format your player and re-transfer your songs. The best way to format the player is by changing the player to MSC, then connect it to your computer and open My Computer and right-click and format the player remove the quick format then click start. :D
So did you get your answer, or do you still need a solution. Stop confusing me =P
If you still need an answer, and I think I know what your saying, then without using rhapsody you can connect to your Sansa e250 VIA "My Computer" in the "Start Menu" and click and drag music onto your Sansa e250.
These are the most common methods for recovering Sandisk's Sansa Mp3
Players. I have been almost universally successful in recovering Sansa
players using one or a combination of these methods. These methods do
not work if you are having synchronization or music format issues -
they are for recovering a player that will not power up, freezes,
flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the
computer and open Windows Media Player. Click on the Sync tab. Pull
down the drop down menu underneath the Sync tab by moving your cursor
over the Sync tab and left clicking on the little black arrow
underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary
slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware
upgrade from Sansa - it updates the firmware and erases every song in
the player all at once. Note: this method doesn't work if already have
the latest firmware. Go to this website and click "Firmware Updater" to
find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off,
hold in the volume + button, and reconnect the player to the computer
while holding the volume + button in. Keep holding the volume + button
for an additional 5-50 seconds. Windows should eventually go into
recovery mode and revive the player- it will pop up a window that says
Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods
to get them to work properly. Disconnect your Sansa player BEFORE
shutting down your computer. -Tha Mp3 Doctor
You must connect the Sansa to the original computer that you loaded it from, and your Rhapsody or other music subscription must still be active.
Otherwise, you will have to start from scratch like this:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
hey smart ones(sarcasm) why dont u just buy the Sansa e250v2
its pretty much the same thing, just without rhapsody, thats how me and my friends are, i bought the one with rhapsody features(Sansa e250R) so i can play the songs that i bought and get free music channels for it, where my friend on the other hand has the Sansa e250v2 without rhapsody, u can still use rhapsody but u cant get free music channels for it, or u could also download best buy music manager or rhapsody and set up a free 31-day account for it to stop saying that for a while, plus if u got ur Sansa e250R from Best Buy, they can replace it, or trade u the sansa that u have with the rhapsody-free one(without rhapsody)
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
I don't understand what that does, it just refreshes my player...
