Canadian Tire's HFBLU-LT100 (BK-600) won't connect to my SPH-m300 Samsung phone but I entry of the passcode (0000) about 20 times before it connect successfully.
When you put the device into pair mode and find it on your phone. You select the device and what happens, what do you mean go away? Try doing a hard reset on your phone, to do this remove the battery from your phone while it is powered on. Reboot it, when it comes back again re-attempt to pair the device to your phone (make sure it is still in pair mode).
That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
you do not have to reset it to pair it with another device. you simply have to put the earpiece into pairing mode again as you did with the first phone and follow the same steps you used initially to pair it to the device that broke.
For Cellular Innovations Mini Blue HFBLU-AX1C. To Pair with Your Phone....
1. Turn OFF Bluetooth Headset 2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode) 3. Search bluetooth device through your mobile phone. 4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
