Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
Posted on Jan 13, 2009
Samsung lcd sound no picture
I own a Samsung LE27T51BX/XEH and three months ago i tried to power it on and i heard the sound but there was no picture. The problem was solved by itself after 1 day, but now 2-3 months later it came up again.
I 've read some things apout t-con board. Is that the solution to my problem and if yes where can i buy it from. I live in Athens Greece.
Thank you very much
John Patrinelis
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 11, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
517
Points
32 In Samsung No Picture just sound and Blue screen?
Anonymous
Level 1:
  • Posted on Sep 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
517
Points
I don't know when you posted this question and I can tell you that I am quite furious with Samsung. My TV 52 inch, started to turn itself on and off on and off every 8 seconds. I did get in touch with the Samsung people and they told me that I could download firm ware that would fix it, but because the tv wouldn't stay on long enough for the menu to come up we couldn't do it. My TV has been out being fixed? in my town for 7 weeks. I just got a call and it is on the way. He told me it was the t-com board and I asked him if the part was new, and he said yes. It better be after all of this time. I did see that you can buy a t-com board on e-bay just a few minutes ago. If you can get your TV to the menu go to Samsung's site and look for a firm ware upgrade. They knew this was going to be a problem and they should have been recalled.
mf
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
3answers
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
My Tv is samsung ln46b530p7f has no picture but I heard sound what is problemI don't any picture
Any capacitor on the power regulator board might have bursted out. Check the power regulator board. Replace it as card basis.
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
2answers
Samsung LN32B360 - had the TV for 9 months and when it is turned on the sound continues, but the picture pops on and off continually about every 20 seconds or so. This started about a month ago.
It can be the backlights inverter board or the power supply section that supplys the power to the inverter board is bad. I hope it is still under warranty. You can how much some of the parts cost here: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN32B360+
Please post back what you find.
1helpful
Samsung 40" lcd sound but no picture.
May be the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
1helpful
Lound humming noise and color distortion
you will be able to fix it. the sound you heard was a color wheel.. the part number is bp96-00674a
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
