One thing to remember about most radios, the RCA pre amp circuit will still work even if the mosfet power amp inside the radio does not. The best way to know if the amp inside the radio works is to use one matching color pair coming off the radio to wire up a random speaker right to the radio. You can use just about any old random 4 ohm speaker that is laying around to check it. The best solution if the amp inside the radio is blown is to replace the radio or amp the pre amp outputs with a small 4 channel amp. Oh, by the way. What vehicle are you connecting this into? And does the vehicle say Bose, Infinity, or ect sound or Premium sound? These usually denote a factory amplifyer already onboard and requires special connections to get the signal to these amps to then be delivered to the speakers.
There should not be a constant voltage present on the output RCA's. They will only put out voltage when there is something playing and it will be a very small and constantly varying amount. If you plug it in and it is still not working you may need to adjust the menu settings on the head unit or the input sensitivity of the amplifier. For example if you plug the RCA's into the Rear outputs of the head unit and the Fader setting is all the way forward, you will not get any sound. Same goes for the amp settings, if you turn it on and the input sensitivity is set way down then you won't get any sound then either. Cheers, Dan
Yes, keep in mind that the amps have a constant power (the large red wire) and need a remote signal to tell them when to turn on/off. This wire connect to a switched 12v from the ignition or radio blue wire (if aftermarket)
I have looked through most of the answers to the same problem question and found my answer. I thank you very much for your site for the free info as the cost could have been huge to fix it. Now that I no the part the cost is minimal, and I can do it myself(with a little help from my friends).
Again Thank You
Kim Graziano
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support. http://servicemanuals.vstore.ca/
The P52940 uses the CTC195 series main chassis. The most common reason for the set not to start up is a shorted flyback (high voltage) transformer. The set actually does try to start, but the computer immediately detects the extra current drawn by the shorted flyback and instantly shuts the set back off. The chassis should be checked and the flyback replaced by a qualified tech familiar with RCA projection TV's.
