It will not let me do anything
Unfortunately, an F11 error indicates a short at the keypad. Try unplugging the oven and waiting a minute before restoring the power. If that resets the error, great.
Otherwise, you need to replace parts. Please add a comment with the model number for specific information. Most likely, you need to replace the electronic control unit (clock). However, this error can be a sign of a damaged wiring harness or the secondary control panel in the oven.
If the oven door is locked, you may be able to temporarily unlock it by accessing the switch controlled by the door lock motor. You will need to unplug the oven and pull it out. Then take off the back panel to reach the switch.
I hope this helps. Again please add a comment with the oven model for more assistance.
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
SOURCE: F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
SOURCE: F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
