SOURCE: Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
to test your opener (and antennae) start inside the garage and click the remote. if its ok try again outside the door and keep moving farther away each attempt. if it works up close ok probably the antennae is the problem
The receiver portion of your Main circut board is not working.
try to reset by unplugging your unit for a few seconds and then plug back in. If this doesn't work you will need to replace the logic board.
