Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
My Bosch Maxx WFL 2260 washing machine goes through the cycle but doesn't dissolve the tablets or cleans the clothes. The clothes are still soaking wet when the cycle finishes. How can I solve this?
please email me with solution if you can help, many thanks. [email protected]please email me with solution if you can help, many thanks. [email protected]
AnonymousMar 15, 2014
also didn't dissolve soap tabletalso didn't dissolve soap tablet
AnonymousMar 24, 2014
after washing cycle finishes clothes sometimes have white spots on them.after washing cycle finishes clothes sometimes have white spots on them.
AnonymousMar 27, 2014
After every wash there are black crayon like particles left in the drum and on my clothing. If run the clean drum cycle twice and the particles are still in the drum. I have cleaned all the filters as well.After every wash there are black crayon like particles left in the drum and on my clothing. If run the clean drum cycle twice and the particles are still in the drum. I have cleaned all the filters as well.
You can't post conmments that contain an email address.
Re: Goes through washing cycle but doesn't dissolve the...
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage.
Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
