I go to Setup, Terrestrial, and I choose Channel Program, which scans for channels on "Auto" mode (which I guess means analog and digital channels?). However, the scan stops at some low percentile, and no channels are found. I have specified the tv to depend on "Antenna" instead of "Cable." I do not have anything external attached to the tv (such as an antenna). Why isn't the Toshiba 26'' picking up any channels??
Hi albertogiler,
I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
thank you i understand how it works now
Please help!! I have a Toshiba 26AV502U, currently, the channels are being shown as "analog", however my university campus will soon be switching over to digital. I have a QAM installed, it is a brand new high def, television! How do I switch from my 35 analog channels to the suppossed 106.3 digital channels? Please help! Im clueless..
how can i tell the tv iam not useing dish iam using a antenna so ican scan antenna channels
I have no cable t.v was working fine now it get no channels and it won't even scan
Can't find antenna
My tv won't pick up attends channels even when I program scan
