Had to remove base/ stand due to it getting broken during move.I want the same base that came with tv when bought.
SOURCE: need to remove base from Proscan 32" TV
The stand
can be removed by unscrewing six phillips-head screws from the back panel. A
plastic insert plate is provided to cover the bottom hole that is left when
removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
SOURCE: how to remove base support from PROSCAN LCD TV( model 26LB30Q)
Remove the srews under AUDIO-L/R and HDMI-1.
SOURCE: new proscan 32 lcd tv. Won't work with sony wireless headphone
Try using the PROSCAN website customer support, to find the answer to you questions.www.oncorpus.com. You will need some type of adaptor from th coax output to the input of you system. For the wireless problem you may need two adapators one from the tv to you receivers and a sound output to wireless adapator. You can call them at their customer support telephone number 1-888-977-6722. I hope this information helps you with your problems.
SOURCE: 42" proscan lcd
you can replace the plug and resistor but make sure you remove any carbon that may of happened,you should be able to scrape it off.if you dont have any luck repost with part number.
SOURCE: I'm trying to wall mount my Proscan 19LB30Q LCD.
Although the instructions don't mention this, you also need to remove two screws on the bottom of the base. Pull the base bottom off. Then remove another screw that holds the base post on.
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
