Refrigerators Logo
Wayne Jenkinson Posted on Dec 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung fridge runs for about 8 seconds and then stops working
Changed PC card DA41-00022A and continues to do the same.
Richard Roth
Level 3:
Top Expert:
  • Refrigerators Master 9,472 Answers
  • Posted on Dec 10, 2012
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626563
Points
28464
What is the complete model number of the unit?
2 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Aug 31, 2010
SOURCE: Loud click,compressor starts, immediately stops.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Anonymous
  • 4323 Answers
  • Posted on Sep 10, 2011
SOURCE: Samsung RS2555SL evaporator is icing
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
2answers
Samsung SRS702GDHSS refrigerator press the control panel button not working
There could be a few reasons why the control panel buttons on your Samsung refrigerator are not working. Here are a few things you can try to fix the issue:
  1. Make sure the fridge is plugged in and the outlet is functioning properly.
  2. Check if the fridge is in Demo Mode. This is a feature that disables the control panel buttons when the fridge is in a store or showroom. To exit Demo Mode, press and hold the "Power Cool" and "Power Freeze" buttons for 8-10 seconds.
  3. Check if the control panel lock feature is activated. This feature prevents the buttons from being pressed accidentally. To deactivate the lock feature, press and hold the "Lighting" and "Fridge" buttons for 8-10 seconds.
  4. If none of these solutions work, there could be an issue with the control panel itself. In this case, it is recommended to contact Samsung customer support or a qualified appliance repair technician for further assistance.
Samsung rb2055sl reezer issue.
88 on its own is a Samsung code.
Did you check the evaporator coils at the back of the freezer. It the defrost timer, or the heater fails, if forms a large block of ice and there is no airflow.
https://all-errors.com/samsung-refrigerator-error-codes-88/
https://www.google.com/search?q=Samsung+RB2055SL+code+88+8
1helpful
Samsung refrigerator model SRS 619 DHSS fridge fan runs continuously when door is closed, open door & fan stops. on fridge side
Fan is supposed to stop when door is opened. Continuous running could bevsensor issue if all else is working properly
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
1helpful
Westinghouse fridge turns it self off to defrost is this normal
If your second hand fridge is over 5 years old, then it might be time to buy a new one. Most fridges nowadays have a lifespan of 5-8 years the most. Danni
Fridge starts and runs for about 8 seconds.
What is the complete model number of your unit?
49helpful
7answers
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Blinking temperature control
hi
this refrigerator having problem related with defrost cycle.fridge is able to defrost after period.please check it as follows
there is timer box located behind the fridge near to compressor with white color knob.attach the clamp meter on one wire of main cord,check current drawn by fridge when comp.is running.turn the timer knob clockwise to hear big tick sound where the comp.will stop,check the current in meter which should be 0.6amp.if it is not showing then there is problem with bimetal or heater which is inside the frizer
4helpful
2answers
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
