Question about Magellan Meridian Platinum GPS Receiver
I load regions to sd card and meridium platium does not recognize
Does the sd card size matter? Do I format the sd card as fat or fat? 32. I have tried many sd cards from 64 md to 128 md. Is the file type an .img file?
  • sailaway147 Jan 14, 2009
    that did answer my questions.
  • 4 Answers
You do not need to screw with an SD card, they are formated to take whatever data you send to them, but in your case check by reading the card to see what is on it BEFORE you put it in the GPS. It may have junk files on it, thus there is no room, unless of course you try to load to much data, THERE IS A LIMIT, suggest you read the GPS manual, and see what the limit of the size of the card is for that GPS, yes there is a limit!
Posted on Jan 13, 2009
6ya staff
SOURCE:
Memory card full
If you already used the card in the same camera, the only thing I can think of is you did switch the lock switch on the SD memory card. Or there must be one or more protected images on your card. If the card comes out of another camera be sure it is a SD or a SDHC card, not bigger than 16 Gbyte because a SDXC card would be one size to big. The manual says max card size 16 GB
If you accedentely formatted the card in the PC (or MAC) it could be you did put a format on the card the camera does not understand. Most camera's use FAT (max 32) and never NTFS.
Try to format the SD card in your PC.
Nov 04, 2013 | GE X500 Digital Camera
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
My Pavillion dv 1000 wont read a micro SD card (in adapter) My camera recognizes and uses the card fine (with adaptor). My laptop recognizes standard sized SD cards fine also. It is not a HC micro SD. ...
If its above 2 gb most older laptops won't because the card is in FAT and not FAT 32. cards 4 gb and over are written differently you can hook your camera up to your computer and transfer then that way or purchase a HCSD card reader for higher capacity cards.
Jan 19, 2011 | HP Pavilion dv7-1129wm Notebook
Sd card format software
Start up a computer with Windows XP, Vista, or Windows 7. Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Computers & Internet
Can't format sandisk micro sd card in my moto rokr
dear sir,
if you have laptop and if it has sd card slot then put the card in the slot
go to my computer
right click on removeable drive
and selet format
selet the "FAT" option on top of the window
click ok
now your card is formatted and you can use it
if you don't have sd card slot then you have to buy or borrow from friend card reader and do it from there.
hope it will solve your problem sir
Mar 26, 2009 | Motorola Mobility ROKR E6 Smartphone
Unknown format
I have 1GB fast speed Goodram sd card and its ok, but i thing more is not possible because of memmory adressing limit.
May 14, 2008 | Kyocera Finecam M410R Digital Camera
Micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me patel352003@gmail.com or patel352003@yahoo.co.in
Jan 07, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Sd card
To reformat the card so the Nikon Coolpix can use it you can use the DOS command 'format' e.g. format g: HOWEVER the default DOS format is FAT32 which the Coolpix will not read. The SD card needs to be formatted in FAT.
Open a DOS command window and type:
Format 'volume' /fs:FAT
Where 'Volume' is the drive letter to be formatted. On my PC this was 'G'. This may be different on your PC. Make sure it isn't an internal drive e.g. C or D!
e.g. format g: /fs:FAT
The card then works OK on the CoolPix
Nov 27, 2007 | Cameras
Magellan Meridian Platinum GPS Receiver Logo
247 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
