1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
SOURCE: Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
SOURCE: Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
SOURCE: how do i clear the maint indicator on a sharp ar m 257
PRESS [#] [INTERUPT] [C] [INTERUPT] [20] [START]
SOURCE: Sharp AR-287 reset machine after doing 160K
press P Interupt C interupt to enter simulation Press 24 & press start button,
Press 4 & enter start button.
Execute and press CA to exit
Dear Sir Maintenance indicator is on in my sharp AR-5620N i tried above steps "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04
still this steps it works , then wt to do.. pls inform me
sir my ar-5618 photocopier heater unit censor or the fusing unit sensor is loose
Mp 37MH 5618
