XBOX won't work. Says can't read disc update from the disc even when a disc isn't in. Regardless of what game we try. This is the code: xbox status code: 397F-3CD6-2800-0F00-C000-0034
Joined fixya just to say "Ross_Cham" thank You, saved one console.
1. Anote second hex data 397F-3CD6-2800-0F00-C000-0034 and go to http://easycalculation.com/hex-converter.php
2. Convert it to decimal and get the update number:
Hex: 3CD6 - Decimal: 15574 Update
4. Extract $Systemupdate and put it into root of a pendrive formatted in fat32
5. Turn off the console and plug the pendrive
6. Turn on the console and wait
7. Enjoy!
SOURCE: Hello, I have a modded
1. Anote second hex data 22FB-3151-B200-0700-C000-0013 and go to http://easycalculation.com/hex-converter.php
Hex: 3151 - Decimal: 12625 Update
3. Go to http://dl.console.se/index.php?dir=Xbox360/uppdateringar/ and seek the correct update. Download it.
(if not try to locate it on google)
4. Extract $Systemupdate and put it into root of a pendrive formatted in fat32 or a CD
5. Turn off the console and plug the pendrive or insert the CD
7. Enjoy!
SOURCE: Cant play supported original xbox games, even with update!!!!!!!!
I'm not sure exactly, the problem could be because you downloaded the update with a burned disc. Sometimes Microsoft catches on to that kind of thing. Even though it says the update was downloaded successfully and is working properly, it may still block the purpose. It could still be blocking the use of original games because of the burned disc you used to download it.
SOURCE: Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within
an hour but please test the below method at your OWN Risk. Please
also note that microsoft is no longer providing Extended warranty for
E74Error.
Check out this DIY Video Guide,that
explains step by step instructions to fix Disc Read Error
yourself within an hour. It also provides the money back guarantee in
case you are not satisfied. As i fixed my Xbox myself so i thought to
share it with you guys.
SOURCE: Xbox wont read discs, unless i hit it....
open tray right??
-check the time and date settings,even the time zone as well
-try to load the disc without the hard drive or memory unit
-look for corrupted files at the memory, delete it
-do the system maintainance,
system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
