SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
SOURCE: frequency out of range on one VPL-EX5, but no
change the resolution to 800x600 and if it works raise the resolution step by step
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Testimonial: "Thanks very much for the help. "
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
SOURCE: sony svga vpl-es2 won't work
Its because for the foot there is switch who give signal to micro processor or system control.Fix it that.Your problem will solve.
