There are places on the TV marked LIKE - -doesn't mean it is EXACT - but you will see what I mean.
Video 1
Video 2
Aux
DVD etc -
Once you see exactly where the DVD player is hook into
Take the REMOTE from the TV -
find SOURCE - start going through the SOURCE modes on the TV changeable using the REMOTE to the TV -
Once you see the Screen that indicates the DVD - [ hint - if you start the DVD movie in it - can make it easier to spot the channel you're on] - If you still have problems - give me the exact model number of the TV and how old it is. I will help you further if needed.
Best of it
Gary @ Fix ya
SOURCE: toshiba sd-k970 dvd player sound but no video.
I presume that you've selected the correct inputs on the TV? Go for HDMI if you have it on your TV. If not use the yellow (composite) and ensure you have nothing in the S-Video (Toshs don't like using composite and S-video at the same time).
SOURCE: DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
SOURCE: How to play a DVD on my Toshiba DVD Player
Using the Toshiba's remote, select either Video (1...X, if several) or S-Video depending to what Video INput the DVD was connected to the Toshiba.
Good luck and kind regards.
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
