NEC VL-PAD-933 Tablet PC Logo
yusuf benallal Posted on Jun 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tablet pc i have a nec versa litepad tablet pc but it will not show any signs of power so i took it to the repair shop and he replaced the d/c jack and it still wont show any signs of power please help
A
Anonymous
THE JACK CONNECTING TO THE MOTHER BOARD CAN EASILY BECOME DISCONNECTED - IT CAN SOMETIMES BE RE-SOLDERED. OTHERWISE A NEW MOTHER BOARD IS NEEDED
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Jun 14, 2007
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
25943
Points
105
Did you depress the reset on the bottom of the unit?
The power light is off The charger is OK with 19Volt The connector is OK and somehow there is a problem with in the power
remove the battery, connect the ac adapter and turn on the laptop. If it turns on then it's your battery. If it doesn't turn on then it is either your ac adapter, your dc jack, or your system board.
If it doesn't turn on then try a different ac adapter from your local pc shop or electronics store. If it still doesn't work then try moving the ac adapter connector and see if it attempts to turn on. If it does then it's your dc jack. If it is your dc jack then you will have to replace it. The problem with that is that it can be pretty expensive to replace it.
The way I have solved this is by ordering a dc jack on ebay or any other online parts supplier and replacing it myself. If you can take your computer apart and put it back together then it's just a matter of desoldering and soldering the new one. If you want you can have a pc or tv shop do the soldering for you.
Have fun and let me know if you have anymore questions.
My lifebook 4215 doesnot display on its screen but can display to an external monitor because the output section of the mb has no small ic like components and a cable jack can I please have a proper...
Call the Fujitsu service 800 number, you may still be under warranty.
It sounds like the inverter has burnt out, take it to a Fujitsu authorized repair shop, your tablet has a security feature that will lock you out if it is opened by an unauthorized repair shop or anyone else for that matter.
They take your tablet security very serious.
1helpful
ASUS U3S change power jack
The motherboard needs to be removed from the laptop in order to repair properly.
WHEN IM ON MY NEC VERSA LITEPAD DOIN WHATEVER THE CURSUR(arrow)CONSTANTLY JUMPS TO THE START MENU AND WONT STOP. HOW DO I STOP IT?
Almost all NEC litepad's have that problem, it's caused by AC current leaking fromt he adapter. Seacrch for LitePad Fix on google for a software solution. Also, preferably change your AC adapter to a OEM.
1helpful
Replacing power jack for hp tc4200 tablet - need manual
I do jack replacements. It requieres soldering and completely dissasembling the laptop. Do not attempt unless you know what you are doing and have the proper tools and work setup. If you still want to do it yourself (at your own risk of course) you basicaly need to take the laptop apart, remove the brokem jack (de-solder) and put in the new one. Use maximum of 15Watt soldering iron. You can get all the tools you need at a local radio shack or electronics store. Good Luck.
I have the same problem with my TC1100
I do not know if this will help your situation any or not. I just posted this in a seperate threadI purchased a used TC1000 for $35 (I just couldn't help myself, despite what the owner state was happening).
It would power on, but no Compaq POST.
Toshiba taught me a simple trick when I was having issues with my X205 gaming laptop. Basically, remove all power sources (including battery). Hold the power slider to the on position for 25 - 30 seconds. Then power back up. You have to discharge whatever electricity is in the board/ps otherwise I believe the MoBo senses additional charge/not enough charge and refuses to boot.
I did this and have had 25 successful boots in a row.
Nec versa litepad motherboard
This might be a 'crazy cursor' related problem. Check this site for the fix:
http://www.veridicus.com/tummy/programming/litepadfix/
Nec versa litepad
Here Try this website they were the cheapest here . Hope this is what you are looking for. should be the right one thanks for looking
http://www.pchub.com/uph/catf/SearchItem.aspx?ft=nec+versa+board&gclid=CPDF3O-VrpACFSBMGgodTANs8g
1helpful
Fujitsu lifebook Won't start up
Please take the laptop to a repair shop for analysis. Possibly faulty motherboard or other parts. Repair price may be high.
Top NEC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a NEC Tablet and eReader Expert? Answer questions, earn points and help others
