American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Logo
A
Anonymous Posted on Dec 07, 2012
I have an american standard toilet 6.01 lpf/1.6 gpf that runs on and off all day long. How can I stop this?
5 Related Answers
Anonymous
  • 1263 Answers
  • Posted on Sep 03, 2008
SOURCE: Water Tank Will Not Stop Running Water
the reason your water keeps running is because the float has not closed of the valve in the stem on the left side. a quick fix is i take the rod that has the float on it and bend it down a little. i also make sure that the plug that fits over the drain seats properly alot of times through age the plug tends to harden up and not seat properly. if you cant get it to seat replace it. if your model has an adjustment screw on the valve body try adjusting that as well.......good luck please rate this
Anonymous
  • Posted on Nov 23, 2008
SOURCE: american standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jun 20, 2009
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Jeff Maul
  • 9 Answers
  • Posted on Jun 22, 2009
SOURCE: hole in back of toilet (stool) leaks water.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
Anonymous
  • 1922 Answers
  • Posted on Oct 13, 2009
SOURCE: running toilet
your float is stuck
How do fix my American standard cadet 3 toilet?
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
Urinal is overflowing, no obstruction in drain
my urinals are overflowing how can I fix this problem I have put a brick in the tank how can I stop this
2helpful
Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
1helpful
2helpful
Flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
American Standard toilet settings screws not adjusted right
sounds like an old tiolet (3.5 gpf) my best answer is to replace with new fluidmaster! (lowes or homedepot) easy fix!
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
