3 year old camcorder's autofucus is no longer working
SOURCE: Canon Vixia HV30 will not be recognized
Video transfer is only possible through Fire wire/ 1394/DV cable.USB can only sned pics to your PC
SOURCE: Just purchased a Canon Vixia HF S10 in USA - Lost English Manual
You can get the manual here
http://gdlp01.c-wss.com/gds/9/0300001969/02/hfs10-s100-nim01-en.pdf
SOURCE: my computer do not recognize my canon vixia hf20
Be sure that you have installed he driver correctly ..and the cable is well plugged...,another thing to check is the camera's display and see if it asks for a connection confirmation in the moment you plug it in ...if it does..choose PC connect ..and after that will work ..
also check into the device manager and see if the camera is present there ..even if it appears in yellow with an ask sign on it ...this meaning that the driver is not installed or damaged or not the proper one..
http://software.canon-europe.com/products/0010719.asp
select the operation system ..download ..reinstall and go for it ...but first check what I suggested..
SOURCE: My Canon VIXIA HV30 won't
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
SOURCE: My Canon (Vixia HG20) camcorder lcd is broken.
You could also replace it on your on if it doesn't involve soldering and to get the LCD go to eBay.com. Some seller can also repair it for you if you want or order the piece and do it own your own.
