SOURCE: HP DLP Parts
the part for the light engine is L1798-60003 I was unable to find a parts distrubutor for it but I think if you bug HP enough they will cave and send you one. I could not find a part number for the color wheel, sorry.
SOURCE: Blurry image, flickering and 6
It is the convergence module that is bad, need to change the convergence IC's, or the buy a new convergence module at www.partsore.com
SOURCE: I have an HP md6580n 65" DLP. It has been in my
Hello
Reset your TV to Factory reset. This will rectify your problem. To turn it to factory reset:
Press Settings, go to Setup > Factory reset, press OK, and select Yes
SOURCE: were can i buy a
Here is a direct link for part # HP L1798-80001 (color wheel):
https://www.myallparts.com/hp-l179880001-color-wheel-p-2178.html
I emailed them and they said they have one in-stock, so you may want to hurry as this seems to be a rare part!
Thank you and best of luck!! :D
Please accept and rate!
SOURCE: my hp 65" dlp tv
Yes, I would advice you to replaced the lamp because high chance that it was already faulty and trigger the symptoms. The unit will not power up unless the bulb is in good condition because of the protection circuitry which will enable if there's a bulb malfunction. You may buy online for the replacement, click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
