I replaced the ge smartwater filter. Will this solve the problem of freezer leaking water and freezing up the drain hole.
SOURCE: Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
SOURCE: Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
SOURCE: I replaced ge smartwater filter water and ice
the taste is because of mixing of diffrent type of smell of your food materials......nothing to worry! just cut a lemon into two half and place it into your freezer and wait for about 8 hours......................have a nice day :-)
