SOURCE: My screen went black and
HI, sorry to hear that...
Basically, if that happens the LCD of your phone is busted. make sure the battery is working also try to use that battery to another phone if does not working that's the time that you have to visit one of your service center in your area...
Thanks
SOURCE: All of a sudden the
Reboot your phone. If the problem persists then the pixels on your LCD have been frozen. You will need to contact the store you bought it from.
SOURCE: my LG phone's screen is black and wont let me see anything
there is nothing wrong with your screen, the problem is
from the flex that connects your screen to the phone's main board. This
flex must have worn out that's why your screen is not displaying any picture.
The
problem is common with flip and slide phones. The flex gets worn out as
a result of constant opening and close of the flip or slide phone.
I
would urge you to replace the flex and I am assuring you that your
screen will display picture again. You might also be lucky to find out that the
flex is not well fix, that is, it may have loosed contact.
If
you cannot change the flex yourself, maybe you should take the phone to
a local repairer within your vicinity, so that the flex can be
fixed/replaced.
Good luck.
SOURCE: LG cell phone
hi there
hav your phone serviced. that has an issue internal. they might have to replace some chips for that. youve checked the battery and still does the same thing.
hope this helps.
fixya!
