How do I get the control panel off to repair door latches on the GE JE2160 microwave?
You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case, it may be a Torx15 or Allen style screw head, and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
Information on where to aquire a special fuse can be got from the manufacturers web site and browse for dealers.The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
