I done my troubleshoot, it says that i did not connect my cable adabter to my pc or network adabter cable is broken. as i know,we didnt need any cable to connect to wireless network isnt it..so i refuse to accept that i need to find or connect any cable network to my pc.. So the real problem must be in the network driver.. so, how i can fix it..give me link or something to download. F.y.i...my pc is acer 4530 (64bit) window7 ultimate
Try here: http://support.acer.com/product/default.aspx?modelId=16 You can verify with a Ethernet Cable connected to the ISP Modem.
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
SOURCE: Acer Aspire 5003WLMi PC Notebook Wireless driver
Try Acer Europe, they actually have drivers, where the US Site usually refers you to Microsoft or to put your Vista disk in the drive.
http://support.acer-euro.com/drivers/notebook/as_5000.html
Hope this helps.
SOURCE: Acer Aspire 5610 Notebook driver download
http://www.drivers-software-download.org/tag/acer-aspire-5610-notebook-driver
http://drivers-download-driver.com/tag/acer-aspire-5610-notebook-driver
http://laptop-notebooks-drivers.com/tag/acer-aspire-5610-notebook-driver
http://driversdownloadsfree.com/tag/acer-aspire-5610-notebook-driver
http://notebooksdrivers.com/tag/acer-aspire-5610-notebook-driver
SOURCE: cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
it still fail
Trouble shooting 101, If it does not connect wirelessly, connect a cable to verify your machine can connect and access the Internet. Troubleshhoting is eliminating the posibilities, and what is left is , most likely the problem, you have us at a disadvantage , You have the machine at hand. For future reference , go to the Acer website Support and drivers:http://support.acer.com/product/default.... .
