TV picture failure with vertical lines, with very occasional picture recovery, occasional pixel "clouding" across screen. TV repair guy identified T-Con board as source of problem, jostling board caused picture to jump, occasionally recover for 1 or two frames but always failed again almost immediately. When looking on ShopJimmy, we found a Samsung board that listed our TV as a match. Is this correct? Just wondering if cross brand parts are a common occurance in this model.
SOURCE: Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
SOURCE: I have a 40" Toshiba
You can try reseating the ribbon cable between the T-CON and the LCD panel, be real careful, very delicate cables.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
Guess the question was a little too expert for this site's "experts". Figured as much. I'll install the Samsung board and update the post to let people know... FFR.
Perhaps you mean "impolite". So not only do you not have any input or information, you're an illiterate troll as well. I see exactly what kind of site this is, a bunch of hack amateurs and belligerent trolls. Is that your area of expertise? Trolling and picking fights with people better than you?
