Trying to install company of heros on HP Pavillion.
System check said all good at the start.
When trying to patch at the end of install error code 10104 keeps coming up.
Richard Singleton
SOURCE: Slow Company of Heroes Gameplay
What the issue is and the only reason I know is because I have had the same issue. You need to go into the game options and change the graphics to a lower option. Your graphics are set too high. Also before you change the graphics right click on the desktop icon and go to properties and then click on compatibility and then click on run as administrator. If that does not work then change the graphics.
SOURCE: I have purchased THQ Company
You can follow the steps below to redeem you code:
* Load Company of Heroes Online
* Visit the Store from the in-game menu
* Click the "Redeem Code" button above your commander
* Enter the bonus code for your free items
If you are receiving an invalid code error in-game, then please note-
When trying to redeem your code if you receive an invalid code error
message, make sure you enter code with the "-"s. Please enter the code
in this format: XXXX-XXXX-XXXX-XXXX-XXXX
Keep in mind that, when I says STORE, this is in the game.. there's a icon with the shopping cart symbol. Click it.
Additional information could find in companyofheroes.com/forums
Good luck.
SOURCE: error code 10104
There are several solutions for this here: http://forums.relicnews.com/showthread.php?187864-Error-10104-lt-Company-of-Heroes Hope this helps.
