Question about Blodgett DFG-100 Gas Single Oven
Need to replace Johnson controls ignition control G67AG-3 on a Blodgett DFG-100-3 convection oven. I was given p/n 20348 by Blodgett, but they didn't give an answer what to do with wire #6 (24 vac
  • Michael Kemmerer Dec 17, 2012
    Disconnect plug causing loss of power from centrifugal sw. to control board. p/n 20348 did work after fixing plug/ socket short.
6ya staff
SOURCE:
Dfg100 oven will light , get to temp, shuts off but wont light by itself again
to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
Apr 16, 2014 | Blodgett DFG-100 Gas Single Oven
Blodgett DFG-XCEL spark but no flame
You need at least 24 volts for the gas valve to open
Jan 21, 2014 | Blodgett DFG-100 Gas Single Oven
Blodgett gas oven 60-90 sec main b urner goes out
After burner on did you hear any spark ignitor if that your flame sensor is dirty or need to replace....good luck
Dec 11, 2013 | Blodgett DFG-100 Gas Single Oven
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Jun 28, 2011 | Blodgett DFG-100 Gas Single Oven
Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 12, 2009 | Blodgett DFG-100 Gas Single Oven
Blodgett Oven won't light
Go here,find what you seek. Great Co.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Dec 12, 2008 | Blodgett 911-DOUBLE Gas Oven
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Blodgett DFG-100 Gas Single Oven Logo
256 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Marvin
Marvin
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
