GPX MW-3847 MP3 Player Logo
Posted on Dec 05, 2012
I asked security to remove write
Can not format
Ana Mora
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 04, 2013
Ana Mora
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
109
Points
5
The hold button on the side might be on. this happened to me while triying to add some files.
2answers
I want to reset mynokia 6500
press *#7370# it will restore but you have to have ur security code for it..... normally it is 12345 or 00000
My phone seems to be continually trying to connect to a PC which I haven't asked it to do and I can't receive or send any messages while it is doing this. How do I get the phone out of this loop
what is the brand of your phone?if nokia, the easiest solution of that problem is to format your phone but first you have to back up your important files. if you have memory card just save it in there and remove the memory card before you start the procedure so that memory card will not be affected. how to format? just type *#7370# and it will ask your security code. the default code is 12345 if you haven't change it. if you change your security code enter it start format your phone.
i hope it will help you
Jul 24, 2011 • Cell Phones
1helpful
2answers
*#7780# is for reset but i want to format
Welcome to Fixya. Here's some code that can be helpful
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
*#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
Thanks for using Fixya
2answers
I have forgotten the security password in 3230 so how can i remove the password or format the set,when i am putting the format code it is asking security code.What can i do ?
The best thing is to format the phone.
To format nokia Nokia 3230 mobile please follow the below steps.
Please download the software called as 'Psiloc System Tools'.
You can download the system tool software from below website
http://gallery.mobile9.com/f/1047847/
Install it in your phone memory.DONOT install in your memory card because we will be removing the memory card.
Remove the memory card
Open the installed software.
Go to 'TOOLS'
You will find the option called as 'format phone',select it.
It will ask for confirmation, confirm it and it will format your phone.
It will restart while formatting and this process takes several minutes.
Once the mobile is started your mobile is formatted.
NOTE: Formatting will delete all your content from your phone memory.Take back up before formatting.
Thank you
2helpful
How to format nokia 6030
1.. Turn your device off. Remove SIM card and MMC card (actually, you do not need to remove these, but after format remember to format memory card and reboot phone). Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad Together. Turn your device on while you are pressing the three buttons. You should now see "Formatting .." on the Screen! Leave the buttons now... 2
You can remove the mmc but keep the sim card and restart your phone. Then press the keys *#7370#. The phone would ask a confirmation. Select yes. Then it will ask for a code. The code is 12345 (the default)..or your own selected security code.. There you are! your phone will restart with all the phone memory formatted.
http://www.nokia.com/phones/files/guides/Nokia_6030_UG_en.pdf
3helpful
PEN Drive Prob
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
2helpful
2answers
I have nokia 6288 and dont know what key that format it. how can i format it.... plz tell me..
I have a nokia 6288 mobile i forget my security code and i want to format may cell but trying formating code *#7370# mobile ask for security code i try default security code 12345 but not code not valid can some one help me.
2helpful
Formating n70i
hi guy you can type *#7370# when asked restore factory setting then type yes and when asked security code then type 12345
and another solution press *+1+dial key+power on key combianly and wait until when u watch nokia then remove finger from key. that will be format ur phone. thanks. by joy. if more problem then u can mail me " [email protected]"
How to remove the security code of nokia 3100?
hi there
i used this phone long time ago
i dont exactly remember the menu
but i will help you to do that
you need to browse through the phone.
steps
-- go to menues
-- find settings option
-- go to settings
-- find phone option
-- go to phone
-- find default settings / restore settings / factory settings something similar to this
-- when you press ok it will ask for the security password
-- if it will not ask then you are lucky
-- but if it will ask
-- 0000 try first
-- if it dosenot work then try 12345
if none of them work means some one manually changes the security code..
-- you cannot format until you find the right code
--- if any of the code works then your phone is ready to format
-- after few minutes you will find your phone like the new one.
dont forget to save contacts and msg in to sim card as the format will delete everything from your phone.
thanks.. and hope it will help you
Apr 01, 2009 • Nokia 3100
8helpful
I fergot my security code to my LG Kb770
Hiiiiiii i am having nokia 5310 model.and i forget the security code.now i am having problem with my mobile.so i have to format my mobile when i formating the mobile it asking the security code.plz tell how to format without security code
Oct 22, 2008 • Cell Phones
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
