Onkyo ht-r530 i cannot get my rear speakers to work for 7.1 sound. if i hook them to the front connection they work . i have tried playing it through my xbox 360 my tv and dvd
The 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Hi there!
some times u need to to go to menu and select first that u have coneccted the sb speaker couse maybe u dont have it on!
try if your onkyo it has the function to reproduce pink noise (to calibrate the speakers) and when in the display of the amplifier shows the SB speakers, if u see in the display that the amplifiers is sending sound and dont sound check the volume, usually do that selecting each speaker for increase the output of the amplifier to the speaker.
Good Luck
BTW: must be something easy, just read the manual, you can down it form onkyo.
how can i sdjust the speakers ? i found the button but when i select adj and push enter it doesnt do anything ?
I am trying to use the receiver to play Pandora using a tablet. I hooked to the USB port in the front of the receiver, but it does not pick up the tablet. I pressed the USB button several times with no results.
