Hello all! I am back again. I must confess, my efforts to solve this problem were overcome by other more pressing events, and I was not able to pursue this until now. To restate the problem with the grill on my Jenn Air SVE87600B Range, When I turn on the rear left element, the fan starts but an alarm sound and a Fault Code F2 appears on the LED display shortly thereafter. I looked up the Fault Code F2 on the trouble shooting chart and it directs me to check the "Ohm Sensor", and refers me to a chart for different temps and their corresponding Ohmic values. It goes on to say that if the Ohms Sensor checks out okay then the Power Relay Board should be replaced. Well, I can't seem to find this Ohm Sensor. Can someone direct me to the location of the Ohm Sensor? Thanks!
HiwyYa
SOURCE: Jenn-Air SVE87600B (corrected model#) Grill Fault
I think when they are saying ohm sensor, they are trying to say to test the resistance (ohms) of the temp sensor/thermistor.
So either the element is not shutting off (power supply to it), the temp sensors faulty (or too close) or the element if faulty(would be my first step)
Knowledge is from my own version of logic this is not my field of expertise but decided due to "any guidance request" I'd put my 2 cent in, but I'd say element if you haven't changed it or it is the temp sensing device, but then thinking about it if your last board in another area got zapped then maybe it is whatever circuit that provides power to the element
Cheers
S.
