One of my blades on my dual blade Wolfgang Puck bread machine will no stay on. I comes off during the kneading so I have to pause the machine every few minutes and set the blade back on the shaft. I have cleaned the blade, shaft and area around it perfectly.
If you can give me some advice I'd appreciate it greatly.
Thanks,
Jan in Oregon
Make sure you line the blade up with the post, and push down firmly on the blade. The top of the post should be even with the top of the blade.
(I occassionally forget to push down, and have that problem. When I do push it down (not real hard) I do not have the problem). After bread is removed, I fill the pan with warm water to make it easier to remove the blades from the pan.
I have the same problem! AND the blades are shaving the grey material they are made of into my dough!! Blech...They are replacing the blades, but I am not convinced that will solve the problem.
Call Wolfgang Puck's 800 #
