Question about Maytag Dependable Care LAT9706
How do you remoce the start switch on a servis caress M2010?
I need to remove the switch to replace it, but cant get it out. Can anyone help?
  • 45 Answers
It's probably a broken lid switch.. There's probably an ovular hole under the lid on the right side. Here's a helpful link to access it.
http://www.applianceaid.com/procedures.h...
Posted on Jan 11, 2009
6ya staff
SOURCE:
Washing Machine does not start
It could also be your line to the machine is fried at the ends where the electrical hook up is. Look at the connections on the back of the machine. One may be fried
Feb 21, 2014 | Washing Machines
Tumble dryer belt servis m2010
Hi,I am trying to fit my new belt and cannot get to the bottom screws to take the front off, please has anyone got any suggestions, thanks
Mar 20, 2012 | Dryers
User manuals for: Hoover soft wave model number HSWD 126-80 and Servis washing machine Caress 1000A, model no: M3101A If someone could help that would be great :-)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 22, 2011 | Washing Machines
I need new thermostat for servis tumble dryer m2007blk cant find anyone that stocks them servis gone to liquidation
try:
http://www.spares2go.co.uk/browse-M200-Tumble_Dryer-SERVIS-spares-m164-p5630.htm
Nov 25, 2010 | Dryers
Manual instruction for servis caress 1200 a
i want to connect a hot water to my caress1000`a`
is it possible?and how our washing machine could control the temperature.(washing machine has a cold water connection)
Aug 31, 2010 | Washing Machines
I own a SERVIS CARESS 1600 A waching machine and I think something might be stuck between the drum and the drum housing. There is a scraping noise as the drum rotates as if it is knocking against...
the only way in is not easy, there is a possibility that the heating element is touching the drum you would have to remove the back panel take off all connections to the drum at the rear and remember or write down a diagram so you know where things went in other words take the whole machine apart to remove the rear drum panel another way is to rotate the drum with a small screwdriver through one of the drum holes till you feel the element and push the element back down out of harms way sorry I cant help more but its worth a try eric
Dec 25, 2017 | Washing Machines
Need a servis caress 2010 manual. Can you help?
Look online for one might find one to download.
Aug 24, 2010 | Dryers
Can I get a a circuit diagram for a Servis caress 900 washing Mac
Their is usually a wireing scmetac inside the timer and switch housing of most machines.
Aug 25, 2009 | Washing Machines
Dell XPS M2010 Starting Problems
If they've changed everything else, why didn't they replace the power supply? That's the next part to target for replacement, other than the on/off switch (or button) itself. With no system board beep codes it's apparent that the mobo isn't gettting any juice at all.
Also try disconnecting everything from the mobo but the power supply - including pulling add-on cards. One or more attached devices may be contributing to the problem. If it comes to life start adding things back until it fails - you've just identified the culprit.
Good Luck!
May 22, 2009 | Dell Inspiron XPS M2010 Notebook
Servis 1200A caress washing machine trips electric
A wiring harness may be loose and the vibration has worn through the insulation. Put it on the side and take a look for loose wires and rubbing.
Oct 30, 2007 | Maytag Dependable Care LAT9706
Washing Machines Logo
157 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
